Phone heats up and battery drains quickly after 2017.2004.063-20200407 update
Abishek_Stephen
Model Name: Asus zenfone max pro m1
Firmware Version: PKQ1.WW_Phone-16.2017.2004.063 20200407
Rooted or not: No
Frequency of Occurrence: after the recent update
APP Name & APP Version (If your issue relates to the app): no
The phone was working without any issues till the update. Now it heats up very much and battery drains a lot quicker than usual. Kindly explain why this is Asus, else you'll see me in consumer court.
13 REPLIES 13
sujanjsr0
Rising Star II
Abishek Stephen
  1. Model Name: Asus zenfone max pro m1
  2. Firmware Version: PKQ1.WW_Phone-16.2017.2004.063 20200407
  3. Rooted or not: No
  4. Frequency of Occurrence: after the recent update
  5. APP Name & APP Version (If your issue relates to the app): no
I am with you bro
veeharish2005
Zen Master I
Abishek Stephen
Download Kaspersky battery life app and clear the apps which are running in the background. Some times the apps that are running in the background drain the battery a lot
vckanandvpp
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/27865/phone-heats-up-and-battery-drains-quickly-after-2017-20...
I am alao using Kaspersky battery life app for almost a year . Phone heating got reduced very much after it. Especially battery drain at idle state.
Abishek_Stephen
veeharish2005
The problem is the update. Fix the battery draining overheating issue. I'm not installing shit.
