10-17-2020
		11:02 AM
 - last edited on
		01-16-2024
		01:06 AM
 by
		 ZenBot
			ZenBot
10-21-2020 08:37 AM
nidhin3I don't think it's very easy for the user or at any situation to access this option accidentally from power button. Because, it need to be pressed Thrice the button (Which can't pressed accidentally). It's not common.https://zentalk.asus.com/en/discussion/comment/126189#Comment_126189
I guess he want the option to turn it on/off to avoid accidental calls. It's common to accidently call the emergency help line.
10-21-2020 09:56 AM
YachendraOnly mistake from user end will be instead of Volume down, mistakenly the user can press Power button. Which is completely the user fault and need to take care by self.https://zentalk.asus.com/en/discussion/comment/126270#Comment_126270
10-27-2020 02:46 AM
11-11-2020 11:36 PM
01-19-2023 06:39 AM
1. Go to Settings->Apps
2. Show System Apps
3. Disable that f**king ZenUI Safeguard.
Worked for me..
