Netflix not supported in Android 10 beta 438 !?!
AsusYouzr
Rising Star II
Model Name: 601kl
Firmware Version: 438
Rooted or not: not
Frequency of Occurrence: always
APP Name & APP Version (If your issue relates to the app): Netflix
Netflix showing my device not compatible on playstore. .
Netflix is not supported on max pro m1 android 10 beta 438 ?
Device is certified on playstore app.
Look at screen shot ..
10 REPLIES 10
drshtmstry
AsusYouzr
  1. Model Name: 601kl
  2. Firmware Version: 438
  3. Rooted or not: not
  4. Frequency of Occurrence: always
  5. APP Name & APP Version (If your issue relates to the app): Netflix
It's because SafetyNet failed. Already discussed on forum. Asus moderator said that they won't fix it.
AsusYouzr
Rising Star II
drshtmstry
https://zentalk.asus.com/en/discussion/44165/netflix-not-supported-in-android-10-beta-438
You are right. This device failed on safety net test. What is this on a 5th revision of beta firmware.. what are they doing for a year !
Yachendra
Rising Star II
AsusYouzr
https://zentalk.asus.com/en/discussion/comment/150347#Comment_150347
Asus is In search of "NEW BUGS" to implement in future updates if any is to be released.
cengizhankirac
AsusYouzr
Update Google play. Turkey is active, the beta 438.
