max pro m2 android 10 bugs in .424 build
gbun
I just updated my phone on 27 may at 8:30 PM
ui is so smooth and much better i thing ui is amazing
navigation gesture working fine,
battery backup is also fine or i can say impressive,
dark mode is also nice,
eis is also working fine,
device is certified,
pubg has hd high graphics
bugs
slow charging (very dissapointing it takes more than 4.5 hours to charge from 1% to 100% but is pie it takes only 2.5 hours)
round corner is missing
ringing and notification sound is low
in speaker there is no bass and sound is also low little bit
and the suggestion from setting is not removing
notification light blinks sometimes green sometimes yellowish white
features we want
google assistant ambient mode
call recording feature in phone app
Y_ASUS
Zen Master I
Hi gbun,
We've replied you in this thread: https://zentalk.asus.com/en/discussion/29212/max-pro-m2-beta-2-bugs
>Thanks for your suggestion, we've collected this suggestion and forwarded to relevant teams. This idea will be taken into consideration as a future design.
