Max pro m1 ZB602KL: Audio bugs output, Android 10 beta build 432
rumputliar30
I have some problem with Android 10 beta build 432.
Bugs report:
Sound audio via headset drop if i play music player and open youtube web together.
Sound quality via headset little bit sibilance.
Please improve sound quality,i am feel something wrong with this audio quality. Because i am listen music everyday.
This update change audio codec from 24bit to 32 bit. 32 bit Hi-Res audio codec not support for Poweramp.output volume very low and flat sound.please change to 24 bit/48khz.
Sound volume not increased from 70% to 100%. Please fix this bugs for next update.
Camera can't capture RAW photos.
6 REPLIES 6
sujanjsr0
Rising Star II
Sound issue is serious issue for me
deepsaharoy7766
For me also , specifically the speaker nobody is caring about this.. it decreased significantly from v429 to v432 built
RadeonPS
Rising Star II
I adb uninstalled icepower in each build because before doing that sound has been terrible.
After adb uninstallation sound is far better.
Most importantly the BASS is good.
RadeonPS
Rising Star II
rumputliar30
Bugs report:
  1. Sound audio via headset drop if i play music player and open youtube web together.
  2. Sound quality via headset little bit sibilance.
  3. Please improve sound quality,i am feel something wrong with this audio quality. Because i am listen music everyday.
  4. This update change audio codec from 24bit to 32 bit. 32 bit Hi-Res audio codec not support for Poweramp.output volume very low and flat sound.please change to 24 bit/48khz.
  5. Sound volume not increased from 70% to 100%. Please fix this bugs for next update.
  6. Camera can't capture RAW photos.
You should definitely give adb uninstallation of icepower a try.
