07-20-2020 04:58 AM
Admin【Version】
16.2017.2007.094
【Model Name】
ZenFone Max Pro(M2) ZB630KL
【Release Date】
2020/07/20
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Updated Android security patch
- Fixed SIM card name editing issue
[200720] ZenFone Max Pro(M2) ZB630KL_IN_16.2017.2007.094
AdminIf you have received the update please share the experience and battery life with this update.【Version】
16.2017.2007.084
【Model Name】
ZenFone Max Pro (M1) ZB602KL
【Release Date】
2020/07/20
【Release Note】
[200709] ZenFone Max Pro (M1) ZB602KL_WW_16.2017.2007.084
07-20-2020 05:01 AM
veeharish2005i have max pro m2July security patch for asus zenfone max pro m1/M2 has been released.
https://zentalk.asus.com/en/discussion/32172/200720-zenfone-max-pro-m2-zb630kl-in-16-2017-2007-094
https://zentalk.asus.com/en/discussion/32167/200709-zenfone-max-pro-m1-zb602kl-ww-16-2017-2007-084
If you have encountered a bug while using, please explain the issue clearly in the comments so the developer's can find and fix those bugs.
July security patch for asus zenfone max pro m1/m2 released
07-20-2020 05:17 AM
abhaykrishnan02Updates are not released at the same time for everyone. It is rolled out batch by batch so if there is a serious bug or the update bricks the device while updating, they can rollback the update and see what is causing the problem.i have max pro m2
i haven't received it till now
07-20-2020 09:07 AM
veeharish2005kya chutiye log he yaar ek security patch bhi ek sath nahi de sakte...kya bc...worst amd the most impotent company i have ever seen...this max pro m2 will be the last product with asus brand name on it...very disappointed. Sharam karo yaar kitni galiya khaoge...yaar dark mode aur gesture navigation dene me 1 saal laga diya aur he hi kya android 10 me jo inse solve ho nahi ho raha...kya anpad gawar team he yaarhttps://zentalk.asus.com/en/discussion/comment/97940#Comment_97940
So you have to wait for the update to come to your device or if you want to install the update immediately then wait for asus to upload the update on their website.
07-20-2020 11:07 AM
