04-11-2020 09:22 PM - last edited on 01-16-2024 01:27 AM by ZenBot
04-11-2020 09:43 PM
EvandAs Android 10 stable version is going to rollout soon, you can definitely keep using it for next couple of years. After android 10 push, Asus is going to provide normal security patch updates for next one and half year after which they would abandone the device from its support list. So if you want to buy your next phone as a 5G one then keep using your Max Pro M2 for next 2 years.Is max pro m2 still worthy to use for next two years?
In my country, 5g is not applied yet. Should I keep using mpm2 till 5g signal is ready and get the new 5g phone?
what do you think?
Is max pro m2 still worthy for next 2 years?
04-11-2020 11:37 PM
04-11-2020 11:44 PM
mobber.logronioIt lauched with android pie and got 10 beta (stable will be available soon)The android is not updating. I'm stock with Android 8 for more than a year. Don't think about buying this phone. You will regret. Not sure the other units of Asus.
04-12-2020 01:01 AM
AveranYes completely agree with all points you mentioned..https://zentalk.asus.com/en/discussion/comment/70728#Comment_70728
So as a midranger it's very much worth it
