Google Chrome and Android System WebView is not updating on Android 10
achal_badole
I have recently updated my Asus Zenfone Max Pro M1 to Android 10 and found that below two apps is not updating with latest updates,
1) Google Chrome
2) Android System WebView.
Also sometimes mic is not working during outgoing and incoming calls.
6 REPLIES 6
vckanandvpp
Rising Star II
achal.badole
1) Google Chrome
For Google Chrome and Android web view update , clear the cache and data of Google Play Store and Google Play services , it will update after that
veeharish2005
Zen Master I
achal.badole
1) Google Chrome
This issue is not specific to asus zenfone max pro m1 because my nokia 8.1 is also having this issue.
If you go to the review section of webview app In play store. You can see a lot of people are experiencing the same issue in different devices.
mks_bio
achal.badole
1) Google Chrome
I am facing Same problem Google Chrome and Android webview is not being Updated.
mks_bio
vckanandvpp
https://zentalk.asus.com/en/discussion/32811/google-chrome-and-android-system-webview-is-not-updatin...
This process doesn't work.
