For those who have downloaded 17.2017.2004.424
das_souradip
Model Name: zb601kl
Firmware Version: mpm1
Rooted or not: no
Frequency of Occurrence: n.a.
APP Name & APP Version (If your issue relates to the app): fota
Post your feedback here (17.2017.2004.424).
Don't create multiple post for the same
1. Battery and performance
2. Speaker
3. Airtel vowifi
4. Camera 2api
5. Native video call
6. Others (any other improvements)
das_souradip
Please share your feedback here in one post.. it'll be helpful to read.
ChitraK
Bugs in build no.424:
1. Speaker output is very very low.
2. Notification sounds and ringtones are very difficult to hear because of low speaker output.
3. At higher volumes the speaker cracks.
4. In the homescreen the Google search bar is permanently fixed you cannot remove it.
5. When I double tap to turn off the display the lockscreen again lights up then I have to double again to turn it off.
6. Sometimes the notification LED doesn't light up.
7. There is a huge gap between the navigation bar and the actual display content when I use the Android 10 gestures
8. Charging speed have been reduced quite a bit.
9. Vibration is a little low too.
10. Audio via headphone is absolute garbage.
11. Stock camera cannot focus when HDR is turned on.
12. Ovearheats while gaming.
A litte suggestion from my side:
Please remove the AM/PM from the time in 12hour format. Looks very old-fashioned
Hope they fix these in the final stable version
