excessive battery spending
Mustafaevren
ZF Model: ZB602KL
RAM: 4G
Firmware/APP Version: 1902 340
Frequency of Occurrence: Sıklıkla
Rooted: No
APP Name:
Last edited by Mustafaevren on 2019/3/9 19:50 The phone consumes excessive battery latest version I use help please correct this situation before
Mustafaevren
Telefon aşırı pil tüketiyor
Mustafaevren
Y_ASUS
Zen Master I
Mustafaevren posted on 2019/3/10 01:47 The phone consumes excessive battery
Hi Mustafaevren, Is the battery draining when in use or sleep mode? If in use, does it drain when using any specific apps? If there are battery drain issues in sleep mode, in order for us to verify, please kindly follow the steps below and show us the screenshots. 1) Charge the phone to 100% before going to bed > remove the charger and turn off screen> the next morning before using the phone, please screenshot the two pages: a) Settings > Battery b) Settings > Battery > ""Advanced battery usage"" (click on the battery icon to access) 2) Tell me the battery variation: for example 23:00 (100%) > 08:00 (90%) 3) In the meantime, were mobile network, WiFi, and Bluetooth turned on or off? Thank you 🙂
