Can I use 2.4 Amp micro usb cable with asus adapter for charging
pravinglkp
1 ACCEPTED SOLUTION
BlueHunt
Zen Master I
pravinglkp
Original Asus Max Pro M1 does support 5v-2Amp charging. If you are just going to use the micro usb cable with your Asus original adapter, then there won't be any issues. It should work fine.
BlueHunt
Zen Master I
pravinglkp
