Camera issue
Model Name:zenfone max pro m1
Firmware Version:9
Rooted or not:not
Frequency of Occurrence: daily
APP Name & APP Version (If your issue relates to the app):Camera
========================================the selfie camera switching mode symbol is not visible since few days
victor010
Zen Master III
Hi, kindly help us with the following information to find a solution to your query.
1.  Firmware version your device is on.
2.  Kindly help us with a screenshot of the issue.
You may also try following steps:
1. Clear cache & storage of Camera App after backing up & disable/re-enable camera App
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
vshikha756
Camera field modal asus zenphone live4g
