Battery problem
luckymayur071
After the pie update I found a problem in my pro m1 ,Now it's takes time almost 4 hours 0%-100% Please give update to fix battery problem
5 REPLIES 5
pk220017
I am satisfy with you mine also takes 4hour
davidlaw2275
I'm not facing that issue but I do noticed lots of bugs like the charging sound not working and the status bar is too snall
Y_ASUS
Zen Master I
Hi luckymayur071, Now it's takes time almost 4 hours 0%-100% --> Does this mean charging the phone takes 4 hrs? Are you using the original 5V2A adapter? Were you using the phone the same time while you were charging? Could you check how long it takes when charging from 0% to 100%, while the phone is in sleep mode, without using the phone? Thank you 🙂
Y_ASUS
Zen Master I
davidlaw2275 posted on 2019/6/2 17:27 I'm not facing that issue but I do noticed lots of bugs like the charging sound not working and the ...
Hi davidlaw2275, Have you enabled "charging sounds" in Settings > Sound > Advanced > Charging sounds? If the problem still appears, please tell me does it appear every time? Or what specific moments does it appear? Thank you 🙂
