ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST UPDATE STARTED ROLLING OUT
Asus_mod67
Model Name:ZB601KL/ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):NEW
ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST BUILD UPDATE IS ROLLING OUT
Zentalk release notes :-
https://zentalk.asus.com/it/discussion/42096/201222-zenfone-max-pro-m1-zb602kl-ww-17-2018-2012-438#l...
PROOF:-
66 REPLIES 66
zaidnabi123
nidhin3
https://zentalk.asus.com/en/discussion/comment/141796#Comment_141796
Remove all security features like PIN, Fingerprint, Face unlock etc before updating... Then your data 'might' be safe.
Still to stay on the safe side, I would recommend you to take backup of important data.
Thanks bro it worked. No data wiped. Successfully installed 438 beta
zaidnabi123
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/141833#Comment_141833
How's the new beta? the bugs described in previous builds are still there?
Share some screenshots also.
I just installed it. This is for the first time I installed any Android 10 beta version on my phone. Initial impressions Smooth UI.
Yachendra
Rising Star II
umashankarsatnami837
https://zentalk.asus.com/en/discussion/comment/141753#Comment_141753
This is japan version which u have mentioned as WW.
I shared the correct URL for WORLDWIDE SKU.
Check the link once it has WW only.
I don't know why it's routing to JP SKU.
If, any inconvenience with the link. Follow this, copy the URL which I shared and paste it in browser url tab and change "JP" with "WW". It works and can download the WW SKU firmware..
Yachendra
Rising Star II
Check now I re-pasted the same URL.
Now it redirect correctly.
dibyarupprk2011
Rising Star II
https://zentalk.asus.com/en/discussion/comment/141809#Comment_141809
Just look at ur link...u have written WW version and given link of JP.
Either you understand a bit more..or you don't understand a lil bit..
I said..both jp and ww has different urls respectively..
