Asus Zenfone Max Pro M1 Android 10 438 build
zaidnabi123
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Installed 438 build successfully on my Asus Zenfone Max Pro M1
32 REPLIES 32
chaudharyprakas
Any bugs?? And how's the performance??
zaidnabi123
chaudharyprakash404
Found two bugs I think they were in the previous build as well (This is my first Android 10 beta experience)
1. Unable to remove settings suggestions option in Settings option (Check Screenshot)
2. Unable to remove or move the google search bar on home screen
Performance is good so far. Smooth experience.
Not applicable
zaidnabi123
https://zentalk.asus.com/en/discussion/comment/141844#Comment_141844
Battery backup or charging speed??
zaidnabi123
raushanpandit718
https://zentalk.asus.com/en/discussion/comment/141847#Comment_141847
Battery backup seems good. Haven't charged yet
