Asus Max Pro M1
doradla_rohith
Model Name:ASUS_X00TD
Firmware Version:424
Rooted or not:No
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Google Playstore shows updates which is already updated before.I have to update each app 2 to 3 times in a week after update release for an app.
I have updated android 10 version 424 via manual update which is provided on asus max pro m1 firmware page.
1.Unable to remove suggestions on settings
2.Charging time is same and it took 2 hr 50 min to charge my device
3.The speaker and earphones output is low.
4..Finger-print recognisation time is very bad
The time taken to unlock the device after recognisation finger is bad compared to time taken in pie
5.Sometimes Wifi toggle shows connected on notification panel but when i drag notification panel it shows as not connected
6.Unable to move Google widget on home screen
7.Picture in Picture mode doesn't work properly
8.Call recording is not working
There are some bug fixes too in version 424
1.I can turn on/off mobile data while device is locked
2.There is no menu bugs in android 10 compared to pie
3.Wifi calling is enabled for jio
4.Camera2api is enabled
18 REPLIES 18
SIB_SANKAR
OTA Kab Mila Haa Bro
vaibhavjaiswalj
Bro stable ota update kab tk milega.
gandlasridhar
Wifi signal is very weak compared to other mobiles. And also bluetooth signal. And caller ringtone is very low compared to music.
Please fix the wifi and bluetooth signal issues.
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
doradla_rohith
SIB SANKAR
It is not ota update it is beta 2 which is provided in asus firmware page it can be updated manually
