Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
Yachendra
Rising Star II
nidhin3
https://zentalk.asus.com/en/discussion/comment/78020#Comment_78020
Did you remove the password before installing ? Also you downloaded from Asus website, Right ?
Double checking coz a lot of important data is in my phone and I cant afford to loose them.
I didn't removed password before installing the 424 firmware. And my data is safe.
But, it is recommended to take backup before updating or installing any update through FOTA or Manually for your safer side. As you can't blame any one if you loose data.
Riyaz
I think we will never get native video calling support on Max Pro M1...!!!!😫😫😫
msaglam1984
this is not a stable release developer version I think it makes sense to wait for the official version
ZT-8bc5ea17
Plz add Hd graphic in pubg mobile and sound issue are there
roscheray101
  1. Model Name: ZB601KL
  2. Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
  3. Rooted or not: Not
  4. Frequency of Occurrence:
Is that true, the Ambient Display feature isn't available on Android 10??
