07-06-2020 08:48 AM
07-06-2020 11:35 PM
07-07-2020 12:52 AM
Christine_ASUSI re-boot on my phone and the pop up on screen But it rises and disappearsHi สิทธิพงศ์
Thank you for your asking. The cross Android update require manual update, kindly try some stay-at-home troubleshooting tips below:
1. Manual update with phone
Download the file into the root dictionary of the internal storage, aka the outermost place you could put>re-boot the phone>tap the pop-up notification "system update"
2. Manual update with PC
To avoid the zip file be downloaded incompletely, use PC to download the file and put the file into the root dictionary of the internal storage via cable>re-boot the phone>tap the pop-up notification "system update"
Please note that once the update is completed, all data, apps, settings and personal information will be deleted. Kindly backup your data first.
#[Zenfone] How to update firmware on my phone?(Manual Update)
https://www.asus.com/support/FAQ/1009748/
#ZB602KL Firmware Spot
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
07-07-2020 06:26 PM
07-07-2020 06:29 PM
