Android 10 emergency calls problem in Turkey (17.2018.2012.438 ) ZB 602 KL
cengizhankirac
Hello  Christine_ASUS, victor0_ASUS
Emergency calls problem in Turkey, the latest version on your official website was solved with WW-16.2017.2009.087. I have provided feedback for fixing Android 10 beta versions, but when I download and install the 17.2018.2012.438 version, I see that there is no fix on Android 10. Due to this problem on the Vodafone line, our Emergency Call numbers are 112 Ambulance and 155 police lines. This is a very critical issue for us, I ask for a fix in the next update.
cengizhankirac
  1. Model Name: Zenfone Max Pro M1 (zb602kl)
  2. Firmware Version: Sürüm WW-16.2017.2007.084
  3. Rooted or not:
  4. Frequency of Occurrence:
Since the day I bought the device, I cannot call lines such as 155 poly help and 156 jnadarma over vodafone. As a result of the control made in the service and made from the Asus center, it is stated that the problem is caused by Andrid 9, and it can be corrected with an update in September.
I have been victimized during a year and many users are not aware of the problem with their device.
Translated to english with google translate, sorry
Emergency call issue with vodafone line with Android 9
Model Name:ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Christine_ASUS
Community Legend II
Hi friends
Please note that the latest version of ZenFone Max Pro M1 Android 10 beta WW-17.2018.2012.438 does not fix the situation. For Turkish users, kindly remain in Android 9. I will check with the relevant team for the case and keep you updated. Sorry for any inconvenience it may be caused.
cengizhankirac
Christine_ASUS
Hi friends
Asus Turkey Service with the error in the results of your labors center is a situation that arose after he conveyed Android 8. Afterwards, the android 9 beta update ending with 85 sent from your center was uploaded to my device, and after 1.5 months, the final update with 87 code was released as said.
I am using Android 10 and I do not want to use Android 9, to fix this problem, I wrote my message to you before, you gave me your feedback that it was delivered to the relevant unit on August 19.
I expect you to correct the mistake as soon as possible and to eliminate our unjust treatment.
ASUS_Bot
Rising Star I
