0.60 -> .424 not working
wesley_b_peres
Model Name: Max Pro M1
Firmware Version: .60
Rooted or not: NO
Frequency of Occurrence:
Hello.
Long story... I was at .063 and than upgraded to "10 Beta 2" .424. (I don' even know how it got right)
I got the brilliant ideia to downgrade to 9 and than upgrade to 10 again with clean install. I did the procedure of "MaxProM1_downgrade_to_9", went back to .060 and tried to upgrade to .424 but no lucky.
The description of .424 says: "This version is only for WW SKU device that with Android 9 OS WW-16.2017.1910.059 & WW-16.2017.1912.060 version." But that's not my case.
Anyone got the update from .060 build?
My plan is to upgrade to .063 again and try to upgrade to .424.
qromodynmc
Rising Star II
I have no idea but why do you guys do such silly things i dont understand.
wesley_b_peres
Update: You can go from .063 to .424
If you are trying from .060 and getting error, try from .063
