Display unlocks while using phone with a headset
Fear
  1. Model Name: ZenFone 9
  2. Firmware Version: WW_33.0804.2060.113 touch panel ver 179
  3. Rooted or not: not
  4. Frequency of Occurrence: every call.
When using phone with a headset, the screen turns on in your pocket, can hang up a call, or does whatever it wants. Pocket mode doesn't help. This makes it impossible to use phone with a headset on the go.
Mansi_ASUS
Hey @Fear,
Can you share a log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Honza
I experience exactly same thing!
ZenBot
Community Manager
Community Manager
