11-19-2019 02:33 PM
11-19-2019 03:38 PM
LP_ASUSEven if that's the case, a conflict is still a conflict. Right?https://zentalk.asus.com/en/discussion/comment/28828#Comment_28828
Wouldn't that be the use case where the two menus overlapping would cause a conflict?
@Kroy I'll forward that suggestion to the team.
11-19-2019 03:39 PM
11-20-2019 02:09 AM
LP_ASUSThat's not the core of the problem, it is not about overlapping these two Volume and Power menus, it is about their vertical position.What is the use case where you need to adjust volume and restart the phone in the same 5 second period?
11-20-2019 02:00 PM
_jis_I see your point. I can forward this and maybe get some clarity on why the relative heights are reversed. I hadn't considered that.https://zentalk.asus.com/en/discussion/comment/28827#Comment_28827
- When you press volume buttons, the Volume menu appears near the power button (lower than it should be).
- When you long press power button, the Power menu appears near volume buttons (higher than it should be).
I myself have no problem with the current position of the Volume menu despite 1), but the Power menu could be shown a little bit lower, just as high as the Volume menu for easy access with your thumb which is already pressing the power button.
11-27-2019 05:37 AM
