08-06-2019 09:00 PM
08-26-2019 03:27 AM
Mine is just perf so different board i think not just different nand and ram chip.lovin2501 said:paras0710 said:Which version you have? Mine is 256/8 GB. Can you check kernel version in your setting does it end with 'perf+' or just 'perf' ?lovin2501 said:Ref. Video attachedlovin2501 said:+ One more thing....you recorded it via inbuilt screen recorder....in mine when I try to do same for even other music streaming app the Audio wizard gets stop working while screen recorder is active. So now 2 issues : a) audio wizard doesn't work for Amazon music . (B) audio wizard stops working for other streaming app also while screen recorder is on/running...... Attaching ref video for issue (b)...audiowizard stops with other music apps too when screenrecorder is runninglovin2501 said:That means Every Asus 6z is behaving different ? No consistency at all ? Something works for someone while not for others.... Strange .....But that's not acceptable need a solution,...paras0710 said:Strange but its working fine on Amazon music for me. See i have uploaded video the music in this video is recorded using phones screen recorder so music doesn't seems to be changing but in reality its working finelovin2501 said:Please look into the attached video...it doesn't works with Amazon Music...I believe many people have same issue, posted in this thread.Anders_ASUS said:I just tried Amazon Music app with the ZenFone 6 speaker, the bundled headphones and a pair of BT headphones. All of them worked with our Audio Wizard. I don't understand why this doesn't work for you
Mine is 64/6 GB. Kernel is perf+(see attached scr shot)
08-26-2019 03:38 AM
So ? It means I have done mistake buying this unit ? For me phone basic things won't work as they do for others?paras0710 said:Mine is just perf so different board i think not just different nand and ram chip.lovin2501 said:paras0710 said:Which version you have? Mine is 256/8 GB. Can you check kernel version in your setting does it end with 'perf+' or just 'perf' ?lovin2501 said:Ref. Video attachedlovin2501 said:+ One more thing....you recorded it via inbuilt screen recorder....in mine when I try to do same for even other music streaming app the Audio wizard gets stop working while screen recorder is active. So now 2 issues : a) audio wizard doesn't work for Amazon music . (B) audio wizard stops working for other streaming app also while screen recorder is on/running...... Attaching ref video for issue (b)...audiowizard stops with other music apps too when screenrecorder is runninglovin2501 said:That means Every Asus 6z is behaving different ? No consistency at all ? Something works for someone while not for others.... Strange .....But that's not acceptable need a solution,...paras0710 said:Strange but its working fine on Amazon music for me. See i have uploaded video the music in this video is recorded using phones screen recorder so music doesn't seems to be changing but in reality its working finelovin2501 said:Please look into the attached video...it doesn't works with Amazon Music...I believe many people have same issue, posted in this thread.Anders_ASUS said:I just tried Amazon Music app with the ZenFone 6 speaker, the bundled headphones and a pair of BT headphones. All of them worked with our Audio Wizard. I don't understand why this doesn't work for you
08-27-2019 02:46 AM
Awaiting response n resolution.lovin2501 said:So ? It means I have done mistake buying this unit ? For me phone basic things won't work as they do for others?paras0710 said:Mine is just perf so different board i think not just different nand and ram chip.lovin2501 said:paras0710 said:Which version you have? Mine is 256/8 GB. Can you check kernel version in your setting does it end with 'perf+' or just 'perf' ?lovin2501 said:Ref. Video attachedlovin2501 said:+ One more thing....you recorded it via inbuilt screen recorder....in mine when I try to do same for even other music streaming app the Audio wizard gets stop working while screen recorder is active. So now 2 issues : a) audio wizard doesn't work for Amazon music . (B) audio wizard stops working for other streaming app also while screen recorder is on/running...... Attaching ref video for issue (b)...audiowizard stops with other music apps too when screenrecorder is runninglovin2501 said:That means Every Asus 6z is behaving different ? No consistency at all ? Something works for someone while not for others.... Strange .....But that's not acceptable need a solution,...paras0710 said:Strange but its working fine on Amazon music for me. See i have uploaded video the music in this video is recorded using phones screen recorder so music doesn't seems to be changing but in reality its working finelovin2501 said:Please look into the attached video...it doesn't works with Amazon Music...I believe many people have same issue, posted in this thread.Anders_ASUS said:I just tried Amazon Music app with the ZenFone 6 speaker, the bundled headphones and a pair of BT headphones. All of them worked with our Audio Wizard. I don't understand why this doesn't work for you
@Anders_ASUS..... Can someone from Asus team provide me the solution ..... ??
08-30-2019 12:11 AM
A: I just updated to latest Amazon Music version on my ZF6 and then Audio Wizard stopped working. Killing both apps didn't fix the issue. But when i restarted my phone, then Audio Wizard started working again. It could be as easy as that you just need to restart your phone+ One more thing....you recorded it via inbuilt screen recorder....in mine when I try to do same for even other music streaming app the Audio wizard gets stop working while screen recorder is active. So now 2 issues : a) audio wizard doesn't work for Amazon music . (B) audio wizard stops working for other streaming app also while screen recorder is on/running...... Attaching ref video for issue (b)...audiowizard stops with other music apps too when screenrecorder is running
08-30-2019 12:21 AM
A. Even restarting doesn't works. Audio wizard do not works with amazon music in any senario for me.Anders_ASUS said:A: I just updated to latest Amazon Music version on my ZF6 and then Audio Wizard stopped working. Killing both apps didn't fix the issue. But when i restarted my phone, then Audio Wizard started working again. It could be as easy as that you just need to restart your phone+ One more thing....you recorded it via inbuilt screen recorder....in mine when I try to do same for even other music streaming app the Audio wizard gets stop working while screen recorder is active. So now 2 issues : a) audio wizard doesn't work for Amazon music . (B) audio wizard stops working for other streaming app also while screen recorder is on/running...... Attaching ref video for issue (b)...audiowizard stops with other music apps too when screenrecorder is running
B: Audio Wizard stops because you have set your screen recorder to internal audio. Change it to microphone and it will work
