Any rumors on zenfone 11 compact?
Hello, does anybody know anything new about zenfone 11 compact release? I am about to get a new phone and cant decide if i should wait a bit more or go with 10. Btw. any other phone with native call recorder?
The message you are trying to access is permanently deleted.
Just a quick post to say that this phone has had the best battery life I've ever had on a phone and I've tested 100's at this point.Basically for my use case I'm getting 3 days between charges.On top of that the phone is snappy, camera's decent and t...
Seems there are Bluetooth connectivity issues when connecting Ray-Ban Metas to ZenFone 11 Ultra. It connects property on initial setup. You see 2 instances of RB Meta in Bluetooth connected devices list (one with Bluetooth logo the other with Headpho...
how do i enable the "background mode" in my zenfone? i cant seem to find the toggle for it
How do I change the layout so that the fixed apps at the bottom of the screen aren't there anymore
I've only had my Zenfone 11 Ultra for a day, but every time I've opened the edge tool it's been by accident. I don't have much need for it anyway since all its shortcuts are also on quick settings or on my home screen.It's my understanding the option...
Hello, I couldn't find the option to show the currently playing music on the always-on display. Does this option exist? Otherwise, this is another reason to make the AOD more useless, as it also doesn't show weather info and it is very dim most of th...
I recently received an Asus Zenfone 11 ultra phone. Unfortunately, for some reason the phone does not connect to the network. When I try to do the same with an old phone, everything works. This means that the problem is not with the SIM card. Does an...
Can you unlock the bootloader on the new Zenfone 11 Ultra?
Is there any way we can bombard Asus' PR and demand them to give back the ability to unlock our phones' bootloader?Like, seriously. I bought the ZF8 cheap, almost a year after its release simply because I planned to flash LineageOS once the support f...
