WiFi Problem on Zenfone 10
tequekama
Hello everyone,
I've been noticing that my Zenfone 10's WiFi would sometimes not detect any networks at all. "Fix connectivity" button does not help with this and my current solution to it is restarting the phone.
Phone's system is up to date and I'm wondering if anyone here has had this problem before?
Uuçisses
mine is working fine, apart from the fact that it doesn't allow me to upgrade to Android 14
Mansi_ASUS
Hey @tequekama,
Can you please share the log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Wi-Fi ”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
