Vivobook Pro 14 OLED (M3401, AMD Ryzen 5000 Series) usb type-c
ophil
System: Ubuntu 22.04
Battery or AC: 63Wh
Model: M3401, AMD Ryzen 5000 Series
Frequency of occurrence: works randomly
Reset OS: reset connections and unplug adaptor
Screenshot or video:
I'm using docking adaptor 5bites UA3C-45-10BK:
Detailed description:sometimes kernel Linux ubuphil 5.15.0-37-generic #39-Ubuntu SMP Wed Jun 1 19:16:45 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux sees and connects to 1GB network, but mostly fails with next messages in the log:
JJun 13 07:12:08 ubuphil kernel: r8152 2-1.2:1.0 enx00e04f6de4af: Tx status -71
Jun 13 07:12:08 ubuphil kernel: NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
Jun 13 07:12:35 ubuphil kernel: net_ratelimit: 23 callbacks suppressed
NetworkManager log:
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3196] device (enx00e04f6de4af): Activation: starting connection 'eth1g' (>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3197] audit: op="connection-activate" uuid="eae73b0a-b44a-326b-b7d1-268e2>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3198] device (enx00e04f6de4af): state change: disconnected -> prepare (re>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3199] manager: NetworkManager state is now CONNECTING
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3200] device (enx00e04f6de4af): state change: prepare -> config (reason '>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3202] device (enx00e04f6de4af): state change: config -> ip-config (reason>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.3206] dhcp4 (enx00e04f6de4af): activation: beginning transaction (timeout>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5804] dhcp4 (enx00e04f6de4af): state changed new lease, address=192.168.2>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5828] device (enx00e04f6de4af): state change: ip-config -> ip-check (reas>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5899] device (enx00e04f6de4af): state change: ip-check -> secondaries (re>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5901] device (enx00e04f6de4af): state change: secondaries -> activated (r>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5903] manager: NetworkManager state is now CONNECTED_LOCAL
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5904] manager: NetworkManager state is now CONNECTED_SITE
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5905] policy: set 'eth1g' (enx00e04f6de4af) as default for IPv4 routing a>
Jun 13 07:21:31 ubuphil NetworkManager[2213]:  [1655094091.5909] device (enx00e04f6de4af): Activation: successful, device activated.
Jun 13 07:21:40 ubuphil NetworkManager[2213]:  [1655094100.2766] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun 13 07:21:55 ubuphil NetworkManager[2213]:  [1655094115.1102] manager: NetworkManager state is now CONNECTED_SITE
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5740] device (enx00e04f6de4af): state change: activated -> deactivating (>
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5742] manager: NetworkManager state is now DISCONNECTING
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5748] audit: op="device-disconnect" interface="enx00e04f6de4af" ifindex=4>
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5839] device (enx00e04f6de4af): state change: deactivating -> disconnecte>
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5843] dhcp4 (enx00e04f6de4af): canceled DHCP transaction
Jun 13 07:22:48 ubuphil NetworkManager[2213]:  [1655094168.5843] dhcp4 (enx00e04f6de4af): activation: beginning transaction (ti
ophil
I tried both 1GB and 100MB ports, as you see from log, the network works ~40 sec, then fails
Falcon_ASUS
ophil
  1. System: Ubuntu 22.04
  2. Battery or AC: 63Wh
  3. Model: M3401, AMD Ryzen 5000 Series
  4. Frequency of occurrence: works randomly
  5. Reset OS: reset connections and unplug adaptor
  6. Screenshot or video:
NetworkManager log:
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3196] device (enx00e04f6de4af): Activation: starting connection 'eth1g' (>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3197] audit: op="connection-activate" uuid="eae73b0a-b44a-326b-b7d1-268e2>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3198] device (enx00e04f6de4af): state change: disconnected -> prepare (re>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3199] manager: NetworkManager state is now CONNECTING
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3200] device (enx00e04f6de4af): state change: prepare -> config (reason '>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3202] device (enx00e04f6de4af): state change: config -> ip-config (reason>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.3206] dhcp4 (enx00e04f6de4af): activation: beginning transaction (timeout>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5804] dhcp4 (enx00e04f6de4af): state changed new lease, address=192.168.2>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5828] device (enx00e04f6de4af): state change: ip-config -> ip-check (reas>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5899] device (enx00e04f6de4af): state change: ip-check -> secondaries (re>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5901] device (enx00e04f6de4af): state change: secondaries -> activated (r>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5903] manager: NetworkManager state is now CONNECTED_LOCAL
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5904] manager: NetworkManager state is now CONNECTED_SITE
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5905] policy: set 'eth1g' (enx00e04f6de4af) as default for IPv4 routing a>
Jun 13 07:21:31 ubuphil NetworkManager[2213]: <info> [1655094091.5909] device (enx00e04f6de4af): Activation: successful, device activated.
Jun 13 07:21:40 ubuphil NetworkManager[2213]: <info> [1655094100.2766] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun 13 07:21:55 ubuphil NetworkManager[2213]: <info> [1655094115.1102] manager: NetworkManager state is now CONNECTED_SITE
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5740] device (enx00e04f6de4af): state change: activated -> deactivating (>
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5742] manager: NetworkManager state is now DISCONNECTING
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5748] audit: op="device-disconnect" interface="enx00e04f6de4af" ifindex=4>
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5839] device (enx00e04f6de4af): state change: deactivating -> disconnecte>
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5843] dhcp4 (enx00e04f6de4af): canceled DHCP transaction
Jun 13 07:22:48 ubuphil NetworkManager[2213]: <info> [1655094168.5843] dhcp4 (enx00e04f6de4af): activation: beginning transaction (ti
@ophil
Sorry, we are unable to comment with you on the use of Linux systems.
We will recommend that you install the system as the Microsoft system.
ASUS_Bot
Rising Star II
