rog phone 2 battery drain
abhiopjit
Model Name:rog phone 2
Firmware Version:17.0240.2103.75
Rooted or not:no
Frequency of Occurrence:
my phone battery drain very quickly like 10% in 25 min with light browsing and youtube. this probably started 1 month ago.
5 REPLIES 5
akkashsaini
Rising Star I
This is mine phone...........
hasantarmaster5
Rising Star I
akkashsaini
Can you share your settings & battery health %
Anders_ASUS
Hall of Fame III
abhiopjit
  1. Model Name:rog phone 2
  2. Firmware Version:17.0240.2103.75
  3. Rooted or not:no
  4. Frequency of Occurrence:
I'd recommend you to backup and factory reset your device as you obviously have an app that's draining your battery. If you still experience similar battery life after the factory reset, then there might be something wrong with your battery.
akkashsaini
Rising Star I
Check these settings I hvnt done anything just after update I reset my phone do hard reset but before that create backup in usb pendrive if necessary
