Not able to mirror cast on my smart tv
Aadish
I don't know but there's a huge bug in inbuilt mirror casting feature in rog phone 2. Whenever i connect to my smart tv it just play for few seconds then it gets stuck and gets connected..firstly i thought it may be problem of my smart tv only but i checked my smart tv and connected ut with other smartphones also it easily got connected and went on smooth...plz resolve this issue
Gustav_ASUS
Community Legend III
@Aadish are you still experiencing this issue after the latest firmware update (2004.9) ?
If you are, a first step would be to reset by going to:
Settings -> System -> Reset options -> Reset Wi-Fi, mobile & Bluetooth
Also, is your wi-fi connection working fine otherwise?
