07-28-2020 10:26 AM
07-28-2020 11:00 AM
AybzHave you tried another charger?Please tell us some basic information before asking for help:
- Model Name: Asus Rog Phone 2
 - Firmware Version:
 - Rooted or not: Not
 - Frequency of Occurrence:Single
 - APP Name & APP Version (If your issue relates to the app):
My phone got dead! Its not even turning on. No led light even on putting on charge!! Please help
07-28-2020 11:07 AM
ronald1985Tried bro...still not workingHave you tried another charger?
Have you tried the other charging port?
Is it the same problem?
07-28-2020 11:20 AM
AybzJust to make sure, did you change cable too?https://zentalk.asus.com/en/discussion/comment/99763#Comment_99763
07-28-2020 11:38 AM
ronald1985This worked. Thnks bro...i thought i lost my phonehttps://zentalk.asus.com/en/discussion/comment/99765#Comment_99765
I don't know if the below helps or something you have tried:
Do you know the phone was on or has the battery died too?
If you know there's battery juice then you can you perform a blind force shutdown on the phone by keeping a hold on volume down and power keys together for a few seconds. Wait for a few seconds, and power on again.
If the battery is drained, keep it on charge and keep a hold on the power button for a couple of minutes.
If none of these work, then I can only suggest the Service Centre.
By the way, what was the firmware you was using or what was you doing just before this happened?
