09-21-2020 08:37 AM
09-21-2020 10:11 AM
NagoI would probably go for getting your money back if you're having the problem for both a likely hardware issue (the advice was to take the phone to service centre when shutting down) and not being able to get updates or if you're wanting to switch from CN to WW because if you do it yourself, you are already voiding warranty. With the money back, you can then decide whether you want to get another ROG device.Please tell us some basic information before asking for help:
- Model Name: Rog Phone 2 (Tencent)
- Firmware Version: WW_16.0622.1906.19_0
- Rooted or not: Not rooted
- Frequency of Occurrence: every time I charge or do something that causes the phone's core temp to rise
- APP Name & APP Version (If your issue relates to the app):
So, I came on here like several other people with the problem of my phone shutting down when the core temperature was raised anywhere above 39 degrees celsius. Upon doing a deep drive into the problem, I noticed that another problem I have is my Tencent version of the phone hasn't been getting updates since I purchased it last year November. Looking around, I found a way to change my Fingerprint and Product ID from "CN" to "WW" but didn't want to do so because I didn't want to void the warranty I still had.
So, I called Asus about my charging problem and Ricardo M. e-mailed back saying "You purchased your device in China and you would have to contact China support for RMA/repairs on your device." Well that's not an option.
My question is, if I do go about changing my Fingerprint and Product ID from "CN" to "WW" and manually update to the latest "WW" firmware on my phone, would that even fix or change the problem I'm having with charging/temperature shut off? I mean, is it a hardware issue or a software issue?
I don't want to go through the hassle of changing and updating my device only to have the underlining charging/temperature issue to still be there. Please advise.
Manual firmware update = solution to charging/temperature shut off??
09-21-2020 10:25 AM
