03-22-2020 05:32 AM
03-22-2020 12:49 PM
fishingforliving1I'm too facing battery drain after update to A10 , I hope it gets fixedSo, finally discovered the battery drain cause, despite the battery setting not telling me anything. I use Wallop as a live wallpaper app. Under Android 9, it was obviously optimised to work well but hasn't been optimised for Android 10 yet. As soon as I removed it, all has been well and battery life is as good, if not better, with A10. I am not looking at 9h 50m screen on time with 120Hz, no battery saving other than killing background apps that are taking the mickey. Hope this helps someone else to figure out their causes as it looks like some apps just aren't optimised yet.
Battery life and Android 10
03-22-2020 02:47 PM
Shivam DahiyaFor me it was Facebook fault. After uninstalling I solved. I reinstalled it after 3 days and now is fine.https://zentalk.asus.com/en/discussion/18108/battery-life-and-android-10
03-31-2020 01:26 PM
fishingforliving1This is very useful info. Thank you so much!So, finally discovered the battery drain cause, despite the battery setting not telling me anything. I use Wallop as a live wallpaper app. Under Android 9, it was obviously optimised to work well but hasn't been optimised for Android 10 yet. As soon as I removed it, all has been well and battery life is as good, if not better, with A10. I am not looking at 9h 50m screen on time with 120Hz, no battery saving other than killing background apps that are taking the mickey. Hope this helps someone else to figure out their causes as it looks like some apps just aren't optimised yet.
