Battery Drain
akhilj66
Rising Star II
After the latest update I have seen a significant fast drop in battery in day to day usage.
7 REPLIES 7
akhilj66
Rising Star II
jyun88
https://zentalk.asus.com/en/discussion/29658/battery-drain
Latest version? 120hertz?
Did you check your background app running without you knowing?
Yes 120hz latest version.
Can you tell me how do I check for background apps, because in memory cleaner I never saw an app that I was not using
jyun88
Rising Star II
Goto developer options and find Running Background apps.
If you don't have Developer options,goto your Software Information,tap few times at Build Number until your see the notification say Developer option is there
gonzaaa_92
Rising Star II
akhilj66
https://zentalk.asus.com/en/discussion/comment/86960#Comment_86960
I don't want to go back through the tedious procedure and downgrade. Also A9 had huge noticeable red tint which was very annoying to me.
Anyways thanks for the info.
Hope they fix it in later updates.
I've updated to A10 when it came out and the red tint issue was still persistent. Then I went back to A9 since the performance of CoD and battery was terrible.
