06-05-2020 12:02 AM
06-09-2020 10:50 PM
jyun88Yes 120hz latest version.https://zentalk.asus.com/en/discussion/29658/battery-drain
Latest version? 120hertz?
Did you check your background app running without you knowing?
06-10-2020 02:30 AM
06-10-2020 02:27 PM
akhilj66I've updated to A10 when it came out and the red tint issue was still persistent. Then I went back to A9 since the performance of CoD and battery was terrible.https://zentalk.asus.com/en/discussion/comment/86960#Comment_86960
I don't want to go back through the tedious procedure and downgrade. Also A9 had huge noticeable red tint which was very annoying to me.
Anyways thanks for the info.
Hope they fix it in later updates.
