07-25-2020 02:50 AM
07-25-2020 02:52 AM
sravan.ezioThis started only after the latest update. It was fine before. No I have te recharge my phone every couple of hour.Please tell us some basic information before asking for help:
- Model Name: ROG Phone 2
- Firmware Version: 2007.27
- Rooted or not: Non rooted
- Frequency of Occurrence: Always
- APP Name & APP Version (If your issue relates to the app):
I am facing an issue of battery drain after the latest update. On non gaming usage it takes around 4 hrs for the battery to reach from 80% to 20%. Android system is shown as the app that uses most of the battery. Please help with this issue.
Battery drain issue after the latest update 2007.27
07-25-2020 05:50 AM
sravan.ezioDoesn't look like there's anything wrong? With 2 hours play of COD and you're on 90hz screen refresh rate, you still have 50+ percent battery.https://zentalk.asus.com/en/discussion/32444/battery-drain-issue-after-the-latest-update-2007-27
07-25-2020 08:44 AM
07-25-2020 09:10 AM
sravan.ezioThe 68% only shows your capcitiy usage over time. It would never be a true reflection on the health of the battery. Infact, AccuBattery causes battery drains due it stopping the phone from sleeping. Therefore, you should never rely on these so called battery monitor. An advice on what can be bad for your phone is if you keep charging and playing at the same time. This is where your phone is discharging and charging.No there is a change in the battery drain time. It's draining faster that how it was before the update. I use my phone always at 90hz but it never had this kind of battery issue. It lasted for quite sometime. But after the new update it's different. I can notice a constant depletion of battery percentage.
Also, attaching an ss from accubattery. It shows 68% health. Do you know why that is?
