03-31-2021
		01:12 AM
 - last edited on
		01-16-2024
		01:57 AM
 by
		 ZenBot
			ZenBot
03-31-2021 02:02 AM
Rajat KumarMine is still working on the latest version .75.Please tell us some basic information before asking for help:
- Model Name: ROG 2
- Firmware Version: Latest .75
- Rooted or not: Non Rooted
- Frequency of Occurrence: Everytime
- APP Name & APP Version (If your issue relates to the app): Audio Wizard
Audio Wizard does not work. Tried restarting the phone. It works for a minute or two then again stops working. I guess this issue is already raised but no solution so far.
Any body with any solution ?
Audio Wizard Does Not Work
ronald1985https://zentalk.asus.com/en/discussion/comment/144779#Comment_144779
Can you do this in the App Info:
Force Stop - Clear Cache and then Clear Storage - Disable and then Re-enable.
The Disable and Re-enable would force reinstalling the factory APK of AudioWizard. I know you have already cleared storage and cache before.
Also if the above doesn't help, this may help with your mic issue in your other post, but I am not sure, but worth giving it a shot.
This will reset all permissions on the device (I mean everything), but doesn't clear any data or anything.
System - Reset options - Reset app preferences
03-31-2021 03:58 AM
03-31-2021 04:12 AM
Rajat KumarGood to hear that it has resolved the issue.Yes to my surprise it got fixed I tried a 100 times earlier but was not able to fix. Hope it stays 😃
