ROG Phone8 Pro wifi problem !! very slow than 3 yrs old phone
mrbaajabb
Hi ,
ROG Phone 8 pro edition !!!   have very slow wifi connection and stable
please check when i just close the door , wifi signle drop to 50% - 80% ++  may be disconnected , compare other phone no drop or drop 5%
please help support.
12 REPLIES 12
infyplay
I don't have such problems with my device.
mickey10021
Rising Star II
New update came out .325 while it was not mention in the change log, the WiFi is much better now.
In my case, I couldn't even connect after a curtain distance. Now it's connected and usable.
mrbaajabb
yes updated and ir already stable , thanks
Hi!
This was indeed a fix in the latest update, so please make sure to update 🙂
on latest update, and Wi-Fi speed is limited to 30Mbps, too slow. it should not be limited.
