rog phone 8 pro wifi issue
mirkococo
At the same place, the speedtest of Wifi Is Always 200-300 mbps/s slower than other models.  It is a very bad user experience for a a flagship product.
4 REPLIES 4
Gtoonm
Rising Star I
Did you try the reboot by holding volume down+power?
That normally fixes the WiFi speed problem
mrbaajabb
me too , wifi very slow after update
Mattias_ASUS
Hi!
This issue issue has been fixed in the latest update 34.1420.1420.316, please make sure to update 🙂
on latest update, and Wi-Fi speed is limited to 30Mbps, too slow. it should not be limited.
tried both .316, now .325, both have same speed limitation.
