ROG Phone 6
Forum Posts
[Game Genie] APK new version for ROG Phone 6/6D only
If you have issue of Game Genie inactivity and crash, please download and install the new version of Game Genie from link below to fix this issue. Please note the apk is for Android 13 & 14 on ROG Phone 6/6D only, and please check the Android version...
Titan_ASUS by Community Manager
  • 2289 Views
  • 0 replies
  • 0 kudos
Asus rog 6 performance issues
I connect to Asus agent for this issues they don't solved this problem they ignore this.they always see the leastest phone not oldest  Asus are very bad I highly recommend if you want buy a gaming phone don't buy Asus phones. Buy red magic or other g...
I connect to Asus agent for this issues they don't solved this problem they ignore this.they always see the leastest phone not oldest Asus are very bad I highly recommend if you want buy a gaming phone don't buy Asus phones. Buy red magic or other ga...
Rog phone 6 performance issues
The rog phone 6 not a performance phone Rog phone 6 is a very bad phone.i can't play free fire in this phone because it has limited performance. And so many lag. Need more performance
Rog phone 6 recording lag issues
In the rog phone 6 recording problem When I started recording on 1080p the game is starting lag. I don't why it's laging.its have 8+gen 1 chip set.i face the problem last 6 monthsModel Name: rog phone 6 Firmware Version: android 14 Rooted or not: not...
Rog phone 6 lag issues
Model Name:rog phone 6 Firmware Version:14Rooted or not:notFrequency of Occurrence:lag issues in 1080p recording continued APP Name & APP Version (If your issue relates to the app):free fire
BATTERY
updated to the max. rog phone 6 pro.1st- when opening it auto shuts down, doesn't matter if i charged it turned off. if i remove the charger then opened it it auto shuts down,2nd- when charging even if i drained it, it will show 100%. the only way to...
Asus rog 6 lag issues
Asus rog 6 has 8 + gen 1 chip set but I don't why Its lag. I play free fire in this phone accuracy problem so many problem in this phone. when phone temperature 28 c° the performance go down I can't play properly
Asus rog 6 recording problem
Model Name:rog phone 6 Firmware Version: android 14Rooted or not: not Frequency of Occurrence : Asus rog 6 has a snapdragon 8+gen 1 chip set but I don't know why it's lag when I record 1080p that is very lag to many lag issues.i don't know why it is ...
