ROG 5S WiFi and Hotspot does not switch on
Goku_5S
It has been 1 year and 4 months since I have purchased my ROG 5S. Ever since I updated my device to Android 13, I have faced a lot of UI issues. Sometimes the System UI will crash and the device will randomly reboot itself. 2 weeks ago, the device rebooted once again and when it came back on the Wi-Fi stopped working. When i try to switch it on from the draw menu, it will stay on "Turning On" status. If I close the drawer and open it up once again, it will go back to switch off status. If I try and switch it On from the settings menu, the button will be greyed out and will not switch on.
If I switch on the hotspot, it will throw "Error" message.
Seems like Asus is rolling out updates without testing them completely.
I have contacted their service personnel. They asked me to boot into safe mode which did not work out. Next they asked me to factory reset the device which I am yet to do as I have to transfer all my data first.
This is not good for a company which charges a premium amount for their device and it fails within just 2 years.
It would be great if it is possible to roll back the updates and go back to Android 12 at least for the time being until they iron out al the existing issues.
Last Update release: 33.0210.0210.229
21 REPLIES 21
Serpenta
Go to service center. They fix the same issue with my phone. Wifi, hotspot error and auto reboot..🫡
Swager
I am facing the same issue, let me know if factory resetting the device resolves the issue. Thank you
I also try to factory reset my phone but it didn't fix the issue. You can also try to reset before going to service center. That's the only way to resolves the wifi and hotspot error
There are only two official service centers listed on the Asus website for the "premium phone" category in India, both of which are pretty far away from me
@Swager
Regarding the issue you have reported, please refer to the following FAQ to see if the situation can be resolved.
https://www.asus.com/support/FAQ/1006657/
If the issue persists, we kindly request you to send your phone for repair to further investigate the matter. Once you obtain the RMA number, please provide it to me so that I can notify the service center about your case.
I have sent you a message, you can provide your contact information and RMA No through the message.
