Performance issue After motherboard replacement
hp9976802431
Rising Star II
1.42ghz only throttling(x mode also) In Game play and stuttering issue,can't play smooth .Very worst performance plz fix in update.
53 REPLIES 53
hp9976802431
Rising Star II
Danishblunt
https://zentalk.asus.com/en/discussion/comment/200588#Comment_200588
The system temp is the temperature you see on armory crate (40-42c). Perfdog is by far the best way of testing your temps while gaming, however you can also use "CPU Throttling test" on play store, remember to turn on temperature in settings when launching it, then you can post a screenshot after running it for 10 minutes.
They are the results. 1st Two graphs with x mode. And Next 2 graphs without x mode...if there any thermal paste issue ...
hp9976802431
Rising Star II
Temperature show 50°c
Without x mode first one screenshot
With x mode second one screenshot
Danishblunt
Hall of Fame I
You're supposed to run it for 10 minutes, not just 1. Also It seems some sensors don't report anything, this is most likely a hardware defect, since the sensors don't show anything, the CPU will automaticly throttle all cores except for the first 2 where it has a reading.
hp9976802431
Rising Star II
Danishblunt
Number of thread 100
End test time 10min
With x mode
Danishblunt
Hall of Fame I
hp9976802431
https://zentalk.asus.com/en/discussion/comment/200595#Comment_200595
End test time 10min
With x mode
CPU load alone doesn't throttle, however the problem is the fact that the sensors are dead on core 2-7. If you play games due to not being able to read the temps the CPU goes beserk as the system temp rises because the GPU is being used.
