BATTERY DRAINING RAPIDLY
rStar
Rising Star II
Model Name: ROG PHONE 5
Firmware Version: WW...188
Rooted or not: NOT
Frequency of Occurrence: OFTEN
APP Name & APP Version (If your issue relates to the app): BATTERY/ BGMI
BATTERY DRAINING RAPIDLY,AND ITS NOT NORMAL.
KINDLY CHECK SCREENSHOT.
41% battery uses under 2 hours.
I kept phone temp under 40° with mini fan behind it.
Earlier it was 14-15% per hour with 90FPS & 10-11% with 60FPS.
9 REPLIES 9
rStar
Rising Star II
soulflywalker
How to do battery callibration?
As I Was able toreach almost 2 days (48h) with 5/6 SOT 60Hz now it's max 30h.
soulflywalker
Squeeze the last drop of juice from battery and hypercharge it to 100%.
soulflywalker
Hi Guys,
Thanks tor support. No significant change noticed after this action.
How to make Phone behave again like in attachment?
If it could previously it mean system optimalization sucks.
I really like this Zen, however now I'm wondeting about replacement...
rStar
Rising Star II
soulflywalker
Hi Guys,
@ARP_ASUS
rStar
Rising Star II
29% and 44% battery drain by Screen only...🤔
Thats totally abnormal.
For me it's less than 4% per hour average.
@ARP_ASUS Kindly look into this.
soulflywalker
Now I tested 90hz highest optimalization level. Only with typing messages and some calls only 3hSoT some about 20hours standby. Nothing much "drainy" for device.
I know this 8flip could much better.
Battery callibration not helped.
Any ideas?
