any solution for wifi problem yet?
krakenss
is this problem solved yet? because its getting really annoying
onyhow
The only way to fix it is to send it to a repair shop, I'm afraid. It's a hardware problem caused by the SoC heat eventually compromising connection to WiFi module.
Falcon_ASUS
@krakenss
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
StalkerPhantom
i dont think so , my phone just had this after a factory reset yesterday , wifi was working fine until 14/02/2024 ~1:30 after which i had to factory reset the phone which caused it to go into a state the wifi wont even turn on , the mobile hotspot shows error but mobile data and ethernet do work which im puzzles me as arent bluetooth wifi and wireless connectivity handled by the same chip ?
