02-01-2021
01:55 PM
- last edited on
01-16-2024
02:04 AM
by
ZenBot
02-02-2021 01:59 AM
02-02-2021 06:55 AM
sgdcfWhen the limit is reached,it will charge all the time if you don't use armoury crate apps,which is not goodPlease tell us some basic information before asking for help:
- Model Name: ROG Phone 3
- Firmware Version: 17.0823.2007.32
- Rooted or not: not rooted
- Frequency of Occurrence: N/A
- APP Name & APP Version (If your issue relates to the app): N/A
Hi will like to ask. With bypass charging feature does it make sense that leaving the charger plugged the whole time be better for the battery? I am unsure of this and when it reaches the set charging limit, I am curious whether I should unplug the charger.
Unplug charger will means I am consuming battery power. But if bypass charging is working, I should leave charger plugged so it won't consume battery power? Which will result in longer battery life?
Please enlighten me.
With bypass charging is it better to leave charger plugged in?
02-24-2021 06:44 AM
