01-18-2021 11:04 PM
01-19-2021 02:04 AM
01-19-2021 04:29 AM
Gustav_ASUS@oponejeffrey@gmail.com As always, reboot your device if you haven't done so already.
You can perform a force stop (long-press the app icon -> App info -> Force stop) and see if that solves your issue.
If the above does not work, reboot your device in safe mode (press power button -> long-press 'Power off' until it asks you to reboot in safe mode) and see if your problem persists. If it doesn't, some third-party app that you've installed is probably at fault.
01-19-2021 06:42 AM
01-21-2021 07:18 PM
