11-19-2020 07:29 AM
11-19-2020 02:19 PM
dtraperoWell,it basically means the phone needs more watts to use,I have the same "issue",but,try to put 30 watt charging and I don't think you'll lose battery.Please tell us some basic information before asking for help:
- Model Name: ROG Phone 3 ZS661KS
- Firmware Version: 17.0823.2009.99
- Rooted or not: no
- Frequency of Occurrence: Really heavy games
- APP Name & APP Version (If your issue relates to the app): Genshin Impact 1.1, Armoury Crate
Ok, so the bypass charging feature received a fix in the last update. The fix was to address the issue in which bypass charging would randomly not activate when told to. But there is a new issue with very heavy games, especially Genshin Impact 1.1. While using bypass charging on the max settings, the phone will eventually discharge 1% or 2% or even 5%. This happens less frequently on lower settings, and does not happen at all on Fortnite max settings or PUBG 90fps. I'm suspecting it is only an issue with overheating with the max settings due to genshin impact being a seriously heavy game. What do you say guys? Is it a software bug or does overheating play an important role?
Bypass charging drain a bit of battery in very heavy games
11-19-2020 09:34 PM
11-26-2020 04:59 PM
GREEKLEADERhave you tried it yet?Well,it basically means the phone needs more watts to use,I have the same "issue",but,try to put 30 watt charging and I don't think you'll lose battery.
