01-03-2021 12:22 PM
01-07-2021 10:24 PM
nightmaster552Okay thank you for your input it means a lot.https://zentalk.asus.com/en/discussion/comment/145135#Comment_145135
When playing certain games the screen uses its high speed refreshrate on touch. That drains a lot of battery, hence your SoT seems very bad but its actually normal. Charge your battery up to full charge, don't play anything for an hour and youll see your value is low and normal, play wilf rift again, your screen will zap electricity. It's perfecly normal, most users here have 0 clue so listening to them is like listening to a 7 year old kid talking about aliens.
01-08-2021 02:07 PM
NengahThere is nothing to fix and they keep the phone for a very long time, some reported long waiting times such as 2months. They will keep it and do nothing with it basicially, it changes nothing.https://zentalk.asus.com/en/discussion/comment/145324#Comment_145324
I'm still gonna send the phone off to Asus just to make sure as I only got it in October and I plan to keep it for a long time so fixing anything now would be best
01-13-2021 11:46 AM
nightmaster552Good news I went into the store where I bought the phone and they just straight up replaced it. So much easier than sending it off.https://zentalk.asus.com/en/discussion/comment/145770#Comment_145770
01-13-2021 01:54 PM
NengahWell at least now you have a new phone that will do exacly the same as the old one I guess.https://zentalk.asus.com/en/discussion/comment/145947#Comment_145947
01-13-2021 01:59 PM
nightmaster552Pray that it doesn't even then they said I can just come straight back and get a refund or a new one.https://zentalk.asus.com/en/discussion/comment/147065#Comment_147065
