[XG Mobile] Hot uplug
XperiAndri
System: Windows 11 Pro [Version 10.0.22621.900]
Battery or AC: AC
Model: GV301QC
Frequency of occurrence: Day by day
Reset OS: Yes
Screenshot or video:
Detailed description:
Sometimes deactivation does not happen whatever I do:
Armory crate services restart
Asus services restart
XG Mobile lock switch off and on without unplugging
Nothing helped until reboot.
However when I did hot unplug (without deactivation) nothing terrible happened. All the apps remain working and just move to the main laptop screen. Only 3050 GPU remain disabled.
So why GPU switch cannot be done after hot unplugging then? Looks like Windows 11 does hot GPU unplug pretty well.
Falcon_ASUS
XperiAndri
  1. System: Windows 11 Pro [Version 10.0.22621.900]
  2. Battery or AC: AC
  3. Model: GV301QC
  4. Frequency of occurrence: Day by day
  5. Reset OS: Yes
  6. Screenshot or video:
  1. Armory crate services restart
  2. Asus services restart
  3. XG Mobile lock switch off and on without unplugging
@XperiAndri
In order to avoid misunderstanding, may I confirm with you again?
So you think it's a problem that there is no error?
Or could you please explain the problem you are having again?
