CPU fan running at 5300RPM in silent mode
AshwinF
System: ASUS TUF F15
Battery or AC: Both in Battery and AC
Model: TUF F15
Frequency of occurrence: Frequently
Reset OS: NO
Screenshot or video: Screenshot
Detailed description: The CPU fan speed runs at 5300 RPM both in battery as well as in AC power when I keep it in Silent, Performance or Turbo mode. Even after restarting my PC sometimes the CPU fan is at the same speed but the temperature is around 40 degree. If I see in the task manager the CPU utilization is also less. Can someone suggest why this occurs.
GEEK_ASUS
Rising Star II
Hi there,
It looks like there is hardware issue of your laptop.
I suggest you contact local service center to do further inspection.
