Armoury Crate Not Opening
parthpatel
When I bought the product ASUS TUF F15 fx507zv-lp094w, the armoury crate was opening at the shop but when I came home and used this laptop for some hours and then tried to open armoury crate but it was not opening. I double clicked to open it but nothing was happening. Also I did system update and then restart the laptop but still the issue was same. It's been 15 days since I purchased this laptop. So please suggest any way to solve this issue. It'll be a great help for me🙏
4 REPLIES 4
Falcon_ASUS
@parthpatel
In your situation, I would recommend uninstalling and reinstalling the Armoury Crate. You can refer to the detailed steps below. Thank you.
[ASUS Armoury Crate] Armoury Crate FAQ
sure I'll try and let you know.
CN-32
I suggest you watch this video on how to reinstall AC into your system if you are having issues with it working properly. Jay explains some of the problems with Armoury Crate (AC).
https://youtu.be/0LPZYX5UPvM?si=ZyuCoNXp6nc7VTmL
