Router with sim card slot
jpcgandre
Hi
I am searching for a 5g wifi 6 router with a nano sim card slot. Does Asus have some models?
Or is there a way to use a sim card to connect to the router via USB port or other port? And if this is possible wouldn't this limit the performance of the router significantly?
Thanks
Aureliannn_ASUS
Hi @jpcgandre ,
we recommend visiting the official Asus website to obtain the most accurate product information.
You can refer to the following link.
WiFi Routers|WiFi 6|ASUS Global
Some routers have a SIM card slot that allows you to insert a SIM card for wireless internet connectivity.
Please note that the performance of using a SIM card to connect to the router may be influenced by various factors, including signal strength, network quality from the service provider, and data rate limitations.
ZenBot
Community Manager
Community Manager
